I've got an 88 with 7m-gte. Mods are 60-1, 2.5" ic piping, divorced downpipe, 3" exhaust with apexi n1 muffler, 255 walbro, cone air filter, etc. I've gapped my plugs properly and double checked the timing. I was hitting cut around 11-12 psi, specifically in 3rd gear or above. Most times I can make it thru 1st and 2nd without hitting cut. To describe cut the engine hesitates briefly then picks back up. I drilled my stock maf and back the screw out a little further. Seemed to improve the cut issue a little bit. Is it normal to hit cut around 11-12? Any suggestions on what my next step should be?
