high idle
ma7089
santa barbara, CA
sometimes when i start my car it will want to idle anywhere between 2k-3k and throw a CEL. but then after a while the CEL will turn off and the car will run fine.. haven't gotten a chance to check the codes.. but i think its my tps or some sort of idle control.. any ideas???
thanks much
Supraboy89
357
Hampton GA
22 is coolant temp sensor. you need to reset your computer by pulling the ecu fuse and start over from there with the codes
ma7089
santa barbara, CA
i took out my efi fuse and disconnected my battery to reset everything.. and now im only throwing two codes.. a 22 and 51.
one for cts and one for tps seytems
