High idle STILL, where to check into next...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
I simply cannot rid myself of this high idle. Its hovering around 1000RPM.
If i adjust the timing via CPS i can get it as low as 730RPM ish but then my timing is WAAAY off, well after (clockwise) the 0* TDC mark on the crank pulley. At 10* its around 1050RPM.
Yes, the ECU terminals are tripped. NO code 51 or any other CEL.
No boost leaks. AFM is reading around 30~31Hz at idle which my understanding is on the higher side when it should typically be around 20~30hz. this is a Lex AFM.
Vacuum is around 20 in.-HG idle and 25 when coasting.
I just recently reinstalled stock cam gears as my aftermarkets failed and marks are lined up dead on with 17 notches in between them.
Should i try retarding each cam gear one notch maybe?
other suggestions?
bowsercake
828
Irvine, Ca
When you turn your AC on when it is idling does the idle raise even further? I know that it is normal to idle at around 1000 with the AC on.
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
mine done this for 200 odd miles after installing the engine, tried to adjust the timing etc tps etc, got it to idle at correct rpm on when setting up, but timing out, so reset the timing to 10deg, then suddenly it settled out to 750 ish rpms!!!
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
so what exactly are the most common things to explore when trying to fix a bad idle, i know for a fact that my knock sensor is bad, i have a new one just been to occupied to get around to changing it, think that could be it maybe?
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i had the same problem and it turned out to be a vaccuum leak because the isc valve gasket wasnt properly sealing because i didnt clean off all of the old gasket when i installed a new one.
my idle is good now, but when i turn on the AC, my idle goes down.....??? what could that be? also my isc doesnt click at all when i shut down. ive tryed 2 different isc valves.
any ideas?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
any ideas?
definate possibility....need to try this one out.
johnathan1
Supra =
Aug 19, 2005
5,056
any ideas?
Then the problem is likely in the wiring to the ISC valve...
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i thought that too. i even got a new wire harness from toyota a few years ago and nothing has changed. im stumped
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
I changed the gasket just now, no difference.
I tried pushing the AC button but it did nothing, however keep in mind i no longer have any AC installed.
I've also noticed a tapping noise when i put my ear to the exhaust...weird?
johnathan1
Supra =
Aug 19, 2005
5,056
Wow, um...then the only things it could be are the Valve itself or the ECU...that is, of course if you aren't throwing any codes.
Test your ISC valve:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=107
Yea, if you have no working AC system, then I don't think that test will work...
And it sounds like you have an exhaust leak.
