HID Conversion
The Juggernaut
52
Saint Louis
Has anybody bought an HID conversion kit for their supra? I'm not talking about buying the bulbs that are blue or white or whatever. The real HID, with real HID bulbs and ballasts and the whole 9 yards. I've thought about doing it, but i'm not sure how much of a difference it would make. I've driven tons of cars with factory HID and it's outstanding lighting, but I'm unsure of conversion kits.
Clueless
980
Columbus, Indiana
I bought some from an unnamed vender, they were mismatched and the ballast that switches from low/high beam quite working...never resolved the issue yet. :icon_evil
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i had hella h4 ecodes on with an hid kit for a while but took it off and.. never got around to putting them back on :p
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
you pretty much have to fab somethig up, with the dot approved projector, oem ballast and bulb, with some DOT approved headlight housings, this is the closest thing you can get near to lega, a lot of the aftermarket hids are illegal
figgie
Twin Cities, Minnesot-ah
HID kits are nothing without the projector housing WITH the built in cutoffs.
That is unless you are an asshole that loves to glare all over the damn road in which case may you and your car get t-swiped by a big rig.
If you are or want to do it with projector housings with built in cutoffs.
Hella 90mm or 50mm Projector. They cost a pretty penny but both are about the ONLY aftermarket projectors that are DOT approved.
Blind Drifter
34
South Florida
I bought Hella glass housings for $85 and then bought a HID kit off ebay for $65. I made a shield to block any light from going downwards ( cause the light that goes down in the housing gets reflected up) and it has come out nice.
figgie
blind drifter;1136355 said:
i bought hella glass housings for $85 and then bought a hid kit off ebay for $65. I made a shield to block any light from going downwards ( cause the light that goes down in the housing gets reflected up) and it has come out nice.
pics!
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i'm with clueless, i had a set of HIDS and hella e-codes. Used them for a little while and the high/low controller stopped working. haven't gotten the issue taken care of so they're sitting on the workbench and my silverstars are back in. can't say i dont miss them though, i loved the things til they stopped working right.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
hey if you dont want to do the conversion on projectors and just want a PNP HID system, i would go with a hella ecode housing and the brightest heat which would be the 4300 but i went with the 5000k heat for oem look,
if you want a projector type the cleanest look is the NSX housings w/ OE HID's but its costly!
figgie
Clueless;1136591 said:
hids I was talking about, not projectors
Of course not. The projectors in question are HIDs.
The reason HID's are not supposed to be sold to consumers is because HID's require (that means MANDATORY) the cut off. No cut off = blind every one because I am an asshole and did not do it right.
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
Same happened here and was never resolved (from the same person no less). Apparently the relay box is not weatherproof and I should have shrink wrapped it, after one night of driving in the rain it shorted and melted my high beam mechanism wiring. Good thing I bought two sets so I could also use the wiring and mismatched heat range bulbs to get at least one good matching set. You get what you pay for. :cry:
