Here's a topic
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Below is a picture of my oil pressure gauge. It stays this way whether the engine is running or not. I checked and the wire is hooked up to the sending unit. No change when I disconnect it either. My question for you is, bad gauge or bad sending unit? I've never seen a gauge do this before.
supra90turbo
shaeff is FTMFW!
MA, 01440
Well, if the gauge does it regardless of whether or not it's hooked up to the sending unit, then it's more than likely the gauge.
I'd find another known working gauge and drop it in. If it doesn't work, it'll only cost like $15 and you can probably sell it on ebay.
mkiiSupraMan18
Needs a new username...
United States
Not so many washers when you shim the pressure relief spring next time. :icon_bigg
I've got an extra oil pressure gauge if you decide you need one.
