HELP!! WTF is this? Poccessed* car!
empera
Authorized Vendor
Philly.
Ok so me and a couple friends finnished up puttin a different 7m engine (original had rod knock) into my 1 friends mk3...after pluggin everthing thing in, setting the timming and filling up the fluids. He goes to start up the car, cranks over, runs really rough for about 3-4 seconds and dies. Tries it again and gets a wierd noise and some greyish smoke out of the intake mani. Side.
We recorded the sound to see if anyone can possibly tell us wats going on because currently we are stuck and have no idea whats going on.
so please any usefull input or info. would be greatly appreciated.
http://home.comcast.net/~NewEra00/memo.amr
Quicktime is needed to play the clip
Thanks,
emp.
empera
Authorized Vendor
Philly.
supraman2251 said:
kind of grayish white smoke?? maybe the harness had a short::winces::
i dun think so cause it would happen more than once...if we keep trying
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
wow, is that a mouse sneezing??? ive never heard a noise like that, no clue as to wut it might be, sorry dude
socc924
CT and Philly
hey man, maybe we can offer a reward to the first person who can correctly identify what the hell that is.
Also to note- the car didnt make this kind of noise when he bought it with the rod knock. It happened after trying to drive it home with the rod knock and did it on the first motor. now with a completely different motor, the rod knock is gone but this problem isnt.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
You got some mice and rats stuck in the head, and when you guys crank it up, they are squeeling to get out.... :rofl:
Actually my car made noises like that when I connected the plug wires wrong. Check you ignition timing and plug wires are connected correctly.... :bigthumb:
empera
Authorized Vendor
Philly.
yea...
njsupra said something about the green temp sensor being unplugged, reason why we got code 22....
Twigger
Ahhh Yeah!!
OlyWA
Are you sure timing is on, how did you completly set it with out starting it. Wonder if it could be a leak between intake runners, or maybe in the isc the oring could be worn out causing it it make a sharp whistle noise. Does it make the noise when you try and start it with the throttle wide open.
empera
Authorized Vendor
Philly.
ok its not that sensor (cause 22 code) because i tried unpluggin it on my car and it started up fine.
doesnt really make the noise all the time, i think u can tell in the sound clip...
how did we set the timming?
1. set the crank to 0
2. Pointed the cam gear notches up
3. aligned the notches on the CPS and put it in
and then started it.
antman
632
TN
did u check the cam gears to make sure they were on right. if your spitting smoke out of the intake side. my quess would be timeing.
steve_mk3
middletown, NJ
Are you sure the engine was at TDC, and not 180 degrees off? that might explain the weasing noise, you would be pushing back into the intake side.
