Help with harness plugs and one vac line at the bottom of the intake
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
gaboonviper85;1470630 said:
I threw the hard pipe section out as it was nasty but I'm sure the silicone vac line I have will route back up there just fine...appreciate the help...I'm just trying to make working on the car easier.
As long as they are going to the same place it will be fine.
I like the hardpipe vacuum lines because they clean up what could be a vacuum line mess and get rid of the potential failure of all of those hosesthat would be right by valve covers, spark plugs, and throttle linkage.
gaboonviper85
3,236
Northeast Philly
nick88;1470629 said:
Can you see this one?
attachment.php
Nope:-(
gaboonviper85
3,236
Northeast Philly
My plugs look different but I'm sure the color of wires and wire count is the same...thanks for all the help...when I get home I'll double check it all:)
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Heres a long shot.
Why don't you rejoin supraforums to get this 411 because all you have to do is plug in the rear speed sensor, bridge the neutral position sensor (2 gauge big wires), and figure out the two wires going to the reverse sensor?
I don't know why theres a million quotes from SF on this page........
nick88
JayHall's Hero
May 10, 2009
794
Zumtizzle;1470651 said:
Heres a long shot.
I was lazy and didn't want to read it all and just quoted it and posted.
gaboonviper85
3,236
Northeast Philly
I couldnt care less....you gave me the info I needed and for that I thank you!
there is very little info on SF that I trust and 99% of the time I can get answers here...just don't feel the need...I may join again but I thinks I is banned lol...although I really don't know:)
and where were you 20 posts ago if it was so easy lol...you failed me Z:-(
gaboonviper85
3,236
Northeast Philly
Next question...instead of messing with the plugs for the neutral switch....is there someplace else I can jumper those wires? Like on the ecu side?....and what about the neutral safety switch at the clutch pedal...will that also need bypassed or can I just leave it be?
I guess it doesn't matter but I wish I'd had known this before installing the harness...
nick88
JayHall's Hero
May 10, 2009
794
Since it is an auto ecu, there will be no clutch switch.
Just make a jumper wire going from the wire in the plug to the others without having to cut the wires for the neutral safety start.
gaboonviper85
3,236
Northeast Philly
No it's a 5spd car...5spd ecu...with an auto harness...
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
You CAN'T jump it in the car. (SEE NEXT POST)
Look at the diagram.
Now doing it this way. Cruise will not work.
The switch at the top of the clutch pedal needs to be wired in line with B W.
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
Okay. No you can't The wire going to the starter is Looped into the Auto Neutral Position sensor!
The black wire there is the actual wire going to the starter.
You're going to need to jump it there or cut your precious loom.
nick88
JayHall's Hero
May 10, 2009
794
Then the nuetral safety start switch bypass is useless because it is a feature on a auto ecu and not a 5spd.
There shouldn't be a problem with just leaving these wires untouched and there as they will have nothing to do with the operation of the ecu.
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
^Wrong!
The White wire on the Neutral safety switch needs to be looped it receives 12 volts from one end (white wire) and sends to the starter (via the black wire)
gaboonviper85
3,236
Northeast Philly
But I still have to jumper the wires on the harness but leave the pedal switch alone?
Fuck I'm all confused lol
