help what to do next ???
supracrazey
5
liverpool
i have a 1987 supra with the stock ct26 turbo and all i have done so far was 3 in exaust from turbo back and intake it has 122 thousand miles on the motor and im shooting for 450 to 500 hp but i dont know what to do next?? i would like so advice!!
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Sleepy John? ;)
2.5" intercooler hardpipes
bigger intercooler
manual or electronic boost controller
adjustable fuel pressure regulator
walbro fuel pump with 12v mod
j-tube bypass
bigger inectors
fuel trimming device or your choice
upgraded or bolt-on turbo
But first, bring the car back into a brand new, pristine condition. I would highly recommend a MHG for that power you want.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
H.G. CHANGE
Atleast! Otherwise rebuild now while you have the money.
Afterwards: search button
l_galyean07
Cedar Rapids
IwantMKIII said:
H.G. CHANGE
head gasket change asap, arp head bolts. youll save yourself a lot of time and money believe me. lexus afm, intercooler, turbo elbow, prepare for a clutch, and save a few thousand dollars on the side in case of the usual supra emergency.
good luck
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
taken from the thread in my previous post.
CKanderson & GrimJack said:
Stage 0
Basic maintenance. Don't even start until you've checked all the vacuum lines, coolant hoses, and everything else that is going to head south on you the instant you try to add performance to a 15 year old car.
Stage 1
K&N high performance air filter kit
3 inch down pipe
3 inch exhaust
*Optional* Test Pipe
*Recommended* 12 volt mod for fuel pump
Stage 2
Stage 1+
HKS BOV kit, or equivalent
3 inch turbo elbow
Boost controller
*Recommended* Shocks and springs
*Recommended* Brake upgrade (pad's, and or lines)
*Highly Recommended* 3 inch test pipe, or high flow cat
Stage 3
Stage 2+
Intercooler Kit
Hard Pipes
Metal head gasket (required at this stage, may be needed for earlier stages)
ARP head studs, or bolts (studs recommended)
Walbro 255 LPH fuel pump
*optional* Fuel pressure regulator
Stage 4 TUNING REQUIRED (Wideband, on a dyno)
Stage3+
Upgraded CT-26 (stock) turbo (57, 60, 60-1 trim)
Lexus AFM
RC 550 cc injectors
Fuel controller (e-manage, Super AFC, F-con)
Upgraded clutch (spec stage 2 or greater)
*Highly recommended* Bigger brakes
*Highly recommended* Coil Over's, and sway bar's
:bigthumb:
i'm using this as a guideline. i've jumped around it a bit, but i'm not doing anything on "stage 4" until after the majority of the suspension is done.
