help wanted
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Hook cherry picker to the two engine lift hooks, and raise the motor slightly. Unbolt the nuts on each end, and remove the bad one. Replace as needed.
If you don't have an engine lift, you can also jack the motor from underneath. Just be sure you don't damage the oil pan. You can jack the motor from the tranny bellhousing.
