Help! Radio, Lumbar, Blower Motor, Power mirrors and windows do not work!
northdakotakid
173
North Dakota
Well I finally got the interior all back together on the Supra today, but there are some issues that have sprung up and I have no idea where to start. When I parked it for the winter, everything worked on the inside. Now today, I fired it up, and I noticed that the blower motor, the radio, the lumbar supports, and the power mirrors and windows are not working at all. I find this very strange especially with the windows. When I reach over to the passenger side, the window will go down, but not back up. Neither switches work on the drivers side. I have not taken the door panels off, so that has not been messed with. I am sure it is something simple, but I am not sure where to look.
Late
125
Appleton, WI
I just took all of that stuff out of my car to transfer into my new shell, there are a lot of plugs are you sure you got em all? Sounds like you might have missed one of the interior grounds
te72
Classifieds Moderator
6,624
9
WHYoming
If you don't have the hazards plugged in, a few things won't work. There is also a plug (two?) under the center console that needs plugged in...
northdakotakid
173
North Dakota
I took the center console off, and sure enough, I forgot to plug in both connectors. As far as the blower motor, the connector came a little loose. And the radio had a blown inline fuse, and the windows just started working again. So all is good and the supra is re-insured and back on the road!
te72
6,624
9
WHYoming
Congrats on getting the Supra back in line. :)
As far as the passenger window, DJT, I had the same issue with my car this past weekend. Was rather sporadic... perhaps our wiring just needs some attention after all these years, could be a bit of grime on the connections?
D.J.T.
877
Arkansas, United States
Yea, Will do friday! Today im working on the MK2's clutch etc. I haven't had time to take a look, but finally i have Friday & Saturday off!
---------- Post added at 01:31 PM ---------- Previous post was at 01:30 PM ----------
northdakotakid;1693057 said:
Thanks man!
D.J.T. I would start there, clean up all connectors and see where that leads you.
yea exactly my thoughts. its embarrassing really. I haul LOTS Of female ass in that car... you have no idea how many girls have said "hey your window doesn't work." lmao
