If you have a karmen vortex car, the MAP-ECU is a nice pile of shit. It is quickly being known as the "Crap-ecu." If you have a hotwire car, you will have better results because of the much higher tuning resolution and the fact that Map-ECU was designed for hotwire cars.Omesh said:Hi,:icon_conf anyone ever use....the Powerhouse MAP ECU Engine Management Piggyback, and if so was it really worth it...i considering it a bit:1zhelp:
dejacky said:If you have a karmen vortex car, the MAP-ECU is a nice pile of shit. It is quickly being known as the "Crap-ecu." If you have a hotwire car, you will have better results because of the much higher tuning resolution and the fact that Map-ECU was designed for hotwire cars.
Yes, I was the karmen vortex map-ecu guinea pig. Unfortunately, it's still installed on my car, but I'm researching stand alone ecu's so I can rid myself of this unreliable & inconsistent piece of junk once and for all. Now, like I said, if you're car is Hotwire type (ex: 2jz-gte obd I), the map-ecu works fine, but for karmen vortex it sucks. I've been through hell and back with the map-ecu (Installed by PHR Dealer so there were no installation errors OR tuning errors) on my na-t 1995 lexus sc300 so I know what I'm talking about :3d_frown: .BoostedFloto said:have you PERSONALLY used it?
Omesh said:Okay i'm considering it or a standalone but i need to know if i am amking a boo, with the piggy back:1zhelp: anymore advice guys
Supracentral said:If money is no object, go with a Motec M800...
JMDigital said:Whats the motec cost? site has no price (thats allways a good sign $$$$$ )
Actually, my map-ecu is bashing is entirely justified. It is a HALF-ASS tune. If I pay $500-$600 and the sales guy tells me it will be perfect for my car, I expect it to work perfect just like stock. Having the tune go to shit when the weather changes with MAP-ECU is completely UNACCEPTABLE. And if all other piggy-backs behave the same way (i.e. half-ass tune that is not consistent with jerky reliability), than a good standalone with a good tune is the only way.boostadikt said:yeah im running map ecu now, overall the car runs and drives great, but tuning with it is definetely a pain in the ass.....
you shouldn't just bash on the map-ecu either because if it is really that terrible you have to start bashing on the maft pro and vpc because they also convert the karmen vortex signal to MAP and will have the same issues
a standalone is a whole other world and if you want to remove the AFM it is by far the best way to go especially on our cars. however i would not reccomend the mega squirt because i had an extremely bad experience with it resulting in a broken piston pin and trashed block. wouldn't it seem that a build it yourself ecu is not the best choice to controll your expensive parts?
if you do not believe me, Tun_x can back up the story the MS is absolutely no good In my opinion.
Perhaps you should also re-read my post. I never said map-ecu was difficult to tune. I was emphasizing that the tune goes to shit and is not consistent, thereby negating the notion of any proper "tune." Map-Ecu is not worth the money for karmen vortex cars. The tune will even go to crap in the same weather conditions...pls don't get me started on all the other issues with map-ecu tooboostadikt said:you need to re-read my post......... and all piggy back ecu's will gradually loose their tune because all you are doing is fooling the factory ecu. you seem to have experience with the map ecu and not much else for piggy backs, because while i agree with you that the map ecu is a large pain in the ass, you will have ALL the same problems trying to convert a Manifold pressure to a KVK voltage for the factory ecu to read and it will be constantly trying to adjust itself. even with an Safc you will gradually loose your tune.
the map ecu is a good product for what it is, yes there is better even in the piggy back world. but if you want to make power and not worry about the car relearning then get a standalone or send your ecu to japan to get flashed.
and while any standalone is a good buy, the megasquirt is at the bottom of the list. something like the Haltech is cheap and is an effective and quality product
Matt if you read the #4 post in this thread, it will answer your question since the Lexus SC300 cars all use 2JZ-GE engines and electronics :nono: .GotToyota? said:Anyone tried a Map Ecu on the GE electronics? I'm considering using this as the piggyback if I'm going the NA-T route.
-Matt
I saw that, but I'm not sure if the 2j's has a flapper AFM like the 7M. :|dejacky said:Matt if you read the #4 post in this thread, it will answer your question since the Lexus SC300 cars all use 2JZ-GE engines and electronics :nono: .
