Help please
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
Im a little stumped. I pulled the motor for a rebuild. Put it all back in, got it wired up but it wont fire. Ive got fuel, and spark. This is whats confusing to me. Oh ya, its a 1J with a microtech standalone. Any ideas would be greaty appriciated
Jayhall
May 7, 2005
1,167
Surrey BC
for the timing, I top dead centered the cams, and the crank, then put the belt on. Other than that I guess im not so sure how to check that it is correct.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Have you double check it if your timing still centered?
Cams line indicator facing up and the crank shaft keyway facing up.
Jayhall
May 7, 2005
1,167
Surrey BC
cam posistioning sensor. Microtech only uses 1, so i switched it the the second sensor and it fired up in an instant
