Help on Explaining Further on how to tune SAF-C
Turbo Habanero
4,229
Tucson,AZ
So i get that you only want to tune Open loop.
And just mess with the high throttle map.
What i don't know about nor have i messed with or will mess with without some input is tuning with the NE points my question is since this is by RPM and not throttle % will the stock computer mess with the tune?
Also what should i do with the Deceleration Air Setting(Dec.-Air) it says it can help out with engine stall from the BOV venting if used correctly any insite on this?
Thanks Jordan
R3N5LOW
116
OREEGON
I noticed that there hasnt been a respond here. I'm in the same boat as you as far as wanting to learn as much as i can about the afc's. The decel air i'm not sure about either and i havent even messed with it. Have you started tuning your afc at all? It seems so weird to have the throttle set at open loop (69% throttle) Im curious to start tuning to see how smooth things will go.
