Help me ID Garrett Turbocharger...
lowtaco
282
Under a damn Toyota
Ive got a freebie today and was curious about it. Mainley concerned if I can use it on my car.
Garrett M12 AR .60 comp. AR .80 exh it is internally wastegated and the Garrett PN is 2901098000
Only thing I know about it was it came from a 4BD2 diesel engine. Supposed to be gated at 12psi. Excellent shape with no play, even came with all the oil and coolant lines.
Take some pictures with a ruler on the exhaust housing where it meets the manifold. It might be a t4 turbo which you would be able to use with a t4 manifold.
lowtaco
282
Under a damn Toyota
Sorry, hope this will help. These were from a few days ago, they were horribly dirty the corrosion on the comp wheel cleaned off tho.
lowtaco
282
Under a damn Toyota
ok turns out it was from a 4HE which is a 4.7 4cy diesel. Im hopeing I can clock the center section, make a adapter and use this Im just affraid the ar80 turbine side will be too big for a stockish 7M.
