I'm fixing my wiring harness and I have found a single wire that I have not been able to identify, however in tracing it I have determined a great deal about what else is connected to this circuit and I am now thoroughly confused.
First, the car is an '88 turbo MT
Now, the wire in question is brown with blue stripes and the loose end is near the ECU plugs on the engine harness. From the end of this wire, about six inches down, there is a factory splice. Into that splice goes the external shielding of the O2 sensor and another identical wire (they are both gray, but the O2 sensor wire itself is white). I've done some checks on this wire and determined that the other end of it is (among other places) grounded at grounding point B on the wiring diagram (this hooks to the head near the intake manifold). The wiring diagram states that a similar wire is connected to E1 on the ECU plugs (the one with 10 pins), however I already have a wire there, and ironically enough, there is continuity between the loose wire and the wire in E1. therefore, this can't be that wire, however I can't think of anything else it could possibly be.
Can anyone identify this wire, or if you have a matching harness, find where the O2 sennsor wire is and look for where the shielding on it is spliced in with the shielding from an identical gray wire and both are conneceted to a brown wire that grounds out at grounding point B and then look for where the fuck the other end of the brown wire is connected and then tell me? Thanks
