Yes.
Intake side, in front of motor mount. Negative battery cable. Will be behind AC comp if its still installed.
Rear ox head on exhaust side (small ground) On bracket that holds the throttle controls, IIRC.
Ground on the trans Xmember (small ground) Drivers side, just a look going up to the actual trans, run through any of the Xmember bolts.
Ground On Trans bolt on intake side of engine, near starter... 2nd bolt up on intake side. Going near the fuel line junction... ish.
No pics, sorry. HTH
*edit*
Few of them on the block...
Two bundles under the intake, just bolt to the intake plenum.
One from the Coil pack
