Help Identify What's Wrong! *With Vids*
Kyle87T
479
Richmond Hill, Ontario, Canada
Hey everyone,
I finally got some footage of my car. It really sounds bad and I dont have any clue what is wrong with it. There is no Power steering fluid in the resevoir as it leaked all over the driveway. The right cam gear is shaking a bit. Here are the videos because I dont know how to explain it any more.
*UPDATE* Vids:
http://www.youtube.com/watch?v=cvzye2GaKLU
http://youtube.com/watch?v=f89KAhqecn4
http://youtube.com/watch?v=PkU6_--s7gE
http://youtube.com/watch?v=jsm41km9n8I
I hope someone knows what could be wrong.
Thank you,
Kyle
It takes an act of congress to watch your video. If you host it somewhere else maybe we can watch it. Can you not host it with supramania video section? Good luck.
johnathan1
Supra =
Aug 19, 2005
5,056
Duh! It's your power steering pump screaming, because it is starved of fluid...put some ATF fluid (read: not power steering fluid, only ATF) and see what happens... Find out where it is leaking from...it is likely coming from on the boots on the rack, or a hose coming from the reservoir.
Kyle87T
479
I know my power steering isnt working somewhere, but that isnt the only problem. It cant be heard very well in the videos, I will see if I can take some more today. There is also a tapping noise very lightly, but I cant pinpoint where it is coming from. Also, the cam gears dont seem to be installed right, they sway a little bit when turning.
IJ. said:
No Powersteer fluid will make that sound as the pump screams it's brains out!
(valvetrain sounds a bit clacky)
Anything specific I should look into?
Demianu27
146
haha, usa
1. Find out where the power steering fluid is leaking from.
2. Tighten your cam gear.
