your slave clutch cylinder is prolly bad and leaking. you can also change the line while your add it. a nice steel braided line cost around $30. and for the slave cylinder go buy a toyota one. i had went cheap the first time and eneded up changing it again not too long ago. installation shouldnt be hard at all. you might need someone to lend you a hand though when its time to bleed the clutch fluid.
Yep, except much easier!
I did mine all alone, and it took no time.
pedal down, tighten bleeder, pedal up, loosen bleeder pedal down, not hard at all. it's all in arms reach from a certain position.
yey all set just in time starting to thunder and rain, might be a very very little on the sofy side but its all good even grabs tighter yay, f*%$ paying labor i almost brought it to a place because i was unsure how to do it but i learned which is a plus on doing it myself
