Help, car still won't start
89TargaT
No Traction FTL...
Jan 30, 2008
88
Missouri
Alright, so I've been having problems with the car and tried everything to get the damn thing running again. I've had a code 14 and 51 for about 2 weeks now. I checked everything and it was fine. Today, I pulled the CPS and re-installed it just to make sure everything with that was good. Got that in and charged the battery for a bit, and then I finally got it to start. It idled fine and ran good for a little bit, then it just died and I haven't been able to start it back up. Also, the code 14 and 51 are back again. I'm lost, and I don't know what else to look for.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Straight off the TSRM
14 Ignition Signal
Diagnosis
* No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
* Igniter and ignition coil circuit
* ECU
Check that out and see if it fixes it.
89TargaT
No Traction FTL...
Jan 30, 2008
88
Missouri
Great I got the car running!!! Check all my wires and connections in the ignition circuit and everything checked out. Wiggled the CPS wires a bit, cleared my codes, got in the car and it started right up. Thanks for the help everyone, this little problem of mine helped me learn a lot even though it was pain in the ass.
