Help break light turn signals
dee242
53
vancouver canada
Hey with my lights off my break lights work but with them on they dont and my turn signals dont work either with the lights off or on. I have an aftermarket steering wheel and quick release hub. My hazards do work btw
dee242
53
vancouver canada
Whel my break lights dont light up with any of the lights on and nymy turn signals dont flash on the dash nor out side the car but if i press the hazard button it will
MkiiiAllDay
159
orange, CA
I highly doubt the quick release install had anything to do with it but what quick release did you install? And have you checked the fuses and harnesses
Sent from my iPad using Tapatalk
rkc14
Virginia (757)
If the above suggestions do not work try looking at your break light relay. It is a small electrical box mounted near your driver side rear tail light. I had a problem of my break lights turning off when I pressed the break pedal. It was a bad solder joint in the circuit of that box.
