So the other night it was cool outside and I went to drive home. I waited for the car to warm up so I could have heat, but even when the car was warm all it would do is blow cold air. The A/C was off and the temperature was set to 85*. Even by the time I had gotten home after a 15 minute drive I still did not have heat. I researched it and I saw a lot of people having problems with the VSV on the heater control valve so I tested that by letting the car warm up and turning the heat on. The bar was pulled up and allowed the hot coolant to flow into the heater core, so I know the heater core is getting hot coolant and that is not the problem.
My car is an 87 N/A Supra with the original climate control box, not the 89+ one. The car has coolant, all the blower speeds work, and the A/C blows ice cold. I tried cycling the temperature up and down, but that made no difference.
If anyone has any input or suggestions as to what could be causing the problem it would be greatly appreciated.
Thanks in advance!
Thanks in advance!
