Headights staying on?
kotu100
1,899
Easton, Ma
i have an 89 n/a chassis with 87 7mgte/harness. i've had this problem since day one, and just used a switch where the relay goes, to manually switch the lights on.
last night they stopped working again, the wire broke somewhere, so im tryinto figure outhow to fix it the correct way.
i came upon a thread back in 07 by Doward, it mentioned something about a violet/white wire coming from the integration relay box. this wire should be grouned with the lights turned on, and open when the switch is off.
If it stays grounded with the switch off, what might i need to do?
if anyone has ANY suggestions they'll be much appreciated.
