Head work
cwapface
Supernerd
Eugene, OR
www.dylanwiggins.com
I'm getting ready to call around for machining prices for my head, but I don't know what I should ask them to do. Gotta have installing the valve stem seals and helicoiling the exhaust studs, but what do I ask for about milling/lapping it? The motor has 158k original miles, never been opened up, and it's all stock. I have an OEM HG and ARPs and i'm going to shim the wastegate to 8psi. After reading through a million threads on SF about which RA you have to have for a MHG, I can't figure out what is best when replacing with a stock gasket. Any help?
chevyeater
wastegate hose is pulled
Long Island, NY
Ask them to check and see if it is cracked first. Then, ask them to see if it is flat. It'd probably be a good idea to check the hardness as well. Then, you can proceed with the rest, knowing you aren't flushing your money on a junk head.
Squid699
Manic Mechanic
Chesapeake, VA
yeah make sure they check for cracks........morons at the machine shop i went to gave me back a head they had done some decent machine work on, but it had a nice crack in one of the oil passages...........morons.
