head gasket
rayall01
901
Westfield, ma
No, the stock gasket bore is too small, and will encroach into the cylinder. IIRC, most quality aftermarket gaskets are available with larger bores.
supradragontoy
Central Point, OR
Your right. You would have to use a headgasket with .050 over bores. If your planning to run a MHG, take it to a machine shop and have them mill it to match your deck. The machine shop you had your block bored at should be able to help you out.
supraken
47
pensacola, FL
oh i made a mistake i thought it was .050" but i got i bored .020" over, i called my machine shop and he told me that i should be fine with a stock bore head gasket, since it was just a .020" bore.
rayall01
901
Westfield, ma
Yeah, well see that you don't f-up next time.:sarcasm:
