Head bolts
fastazzsupra
46
South Carolina
Can you reuse the stock head bolts? If so, does anyone know the specs for the max bolt length? If I use ARP head studs, what do I need to torque them to? I'd appreciate any info or opinions you guys would be willing to give. Thanks.
shaeff
Kurt is FTMFW x2!!!!
11
Around
don't re-use the stockers. it's an all around bad idea. ARP's you can torque to 85ft. lbs. i have my studs torqued to 90ft. lbs.
if you're sticking with a stock composite style gasket, stay with 85.
-shaeff
