He19!!
IHI-RHC7
"The Boss"
Oregon
th1s 1s g01ng t0 be hard... nny ceyb0ard 1s s0 screwed that 1 can't wr1te any 1etters c0rrect1y. d0es any 1 have any adv1se f0r nne.
0n1y the 1eft s1de w0rcs. 91ease he19 nne. 1t 1s a 1a9t09.
1 h09e y0v gvys can he19 nne.
th1s svx.
- 1a2e, that was sv990sed t0 be nny nanne...
spipedong
Level 2 Rythym Rogue
Apr 2, 2005
404
Eugene, OR
yeah, turn your num lock off. If you used a USB keyboard, it probably set your numlock on by default.
It's probably an Fn/Something Key Combination.
My laptop does that all the time when I use a USB keyboard.
It turns the right hand side into the mapping of the 10key you would have on a normal keyboard.
IHI-RHC7
"The Boss"
Oregon
heh, I'm dumb.. learn something new every day. Thanks guys!
It was fun "sounding" like nash for a few posts.
IHI-RHC7
"The Boss"
Oregon
Another Q my hard drive crashed on the PC, so I'm reloading windows on a new HD and its being GAY!
IHI-RHC7
"The Boss"
Oregon
Not the kicking, but Yeah, Num lock was on, I don't use the lappy much, but since the pc died, it has been essential to my success in school. Thanks for all the help,
And thank You, Grant, I appreciate your respect.
-Jake
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
about the HD, is it crashed you should be fine using i over again, do you know details of the crash, and is it XP? by being gay what do yo mean? windows is farily easy to reinstall..., anyways, good to see your comp working again...
IHI-RHC7
"The Boss"
Oregon
Mods- Feel free to move this to Off Topic if need be.
ss91, it was a physical breakdown of the drive detected by the SMART system. the data is preserved, but the drive is unbootable. so I am using an XP install CD and it gets to the point where it will restart and the setup will continue, but setup doesn't continue... it just restarts.
I've tried repairing the existing installation of XP, which I mirrored to another drive, but the admin password has changed...
Loki
The Future is Unwritten
Prince George, B.C.
It was my input that helped, wasn't it Jake?
IHI-RHC7
"The Boss"
Oregon
SS91, this harddrive has been partitioned. I attempted to create a partition in the unused portion of the drive, but it simply ignores my command. I believe you type C to create a new partition in the setup process, but it is as if I had not typed anything, so I'm forced to install into the main partition.
I then created a new folder so that I didn't ruin my existing operating system, because I want to keep any personal files that may be contained in the original folder. It goes through the entire initial install process and then when it reboots, it starts from scratch again...
