having problums with my 7mge
jono
52
Prescott, Arizona, United States
SupraCobra;1293761 said:
Agreed.
Same thing happened to me and the timing on the distributor has to be pretty close to 10 degrees BTDC before it will start. Also, let it sit a while before starting it because the plugs are prob soaked in fuel. Unless you want to take each one out and torch the ends with a flame.
To put the distributor in time.
Put piston 1 at 0 degrees TDC, then take the Distributor cap off and make sure the arm is about 5-10 degrees after the plug wire #1 contact. Line your distributor up according to the TSRM.
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&P=17
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=18
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=19
Make sure you don't mix up Clockwise and counter-clockwise like i did!!! :p
damn man well i got my supra runin and you where right but i was 180 degrees of and the crank shaft needed to be tighten,
jono
52
dumbo;1293361 said:
Can't put my finger on those wires sorry. Where is that vacum line going/coming from? And what is that(wire?) near the bottome left, its black and pretty big?
Like CyFi6 said, did you line up the distributor properly?
Your CEL works, check for codes.
http://cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=23
So does it try or sputter, do you have spark/fuel?
One last thing, even I can tell you, you wont get many responses from the "Old School"/educated guys/gals around here(Who have a wealth of knowledge) unless you put a good effort in and do as people are asking, and believe it or not, grammar is important.
so i got it runin guess i was 180 degress, of one of my supra friend hellped me but the CEL whent of and then after awile it goes on.
yah sorry my grammer aint that realy great and the key pad buttons realy dont work
dumbo
1,913
Albera, Too Far North
Did you check for diagnostic codes yet? It's the link in the last post by you, where you quoted me. DO THIS TRUST ME!!!
Also did you set your ignition timing with E1 and TE1 jumpered?
supraman508
496
maryland
I had a simular prob when mine would'nt start.I't was my battery connections and the battery was low on WATER.check that out,Cause sometimes the simplist things can be the hardest to figure out.good luck
SupraCobra
45
Melbourne, FL
Glad to hear you got it running!
I just did mine back in Feb., glad i could help you out!:icon_bigg
