having a problem
fastsupralife
20g turbo!!!
Sep 4, 2006
iowa
ok i have a 87 turbo supra all stock and today when i was driving it ran fine all day then out of no where when it was fully spooled it did something it felt like fuel cut or misfiring but im only boosting 7 psi so i dont think it's fuel cut so i changed the spark plugs still did it does anyone know what it could be???
shaeff
Kurt is FTMFW x2!!!!
11
Around
check the codes. use the link in my sig. i'm betting you have a boost leak though... check all your piping connections.
-shaeff
do a search for code 14 and there are 25 pages of threads about this. You should be able to find your answers there. If you have anymore problems someone will help you...............lol
dbsupra90
toonar
indiucky
thats an ignition code. reset the code by pulling the efi fuse in the fuse box under the hood. pull for ~30 seconds and replace. see if the code comes back. usually that code wont happen while driving. its when you try to start it w/o an ignition signal.
aside from the code, it sounds like you may have blown off an ic pipe. check all piping and couplers.
shaeff
11
Around
fastsupralife said:
it's throwing a code but how do i read the codes?
did you even read my post? the link that was provided for you is right in my sig. it says **check your codes**
i can't help you if you won't help yourself...
-shaeff
