Hats off to Poodles or grinding noise when clutch pedal is pressed
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Thrust bearing diagnosis:
1. Have someone press the clutch pedal while you watch for movement. If no movement seen, don't give up, go to step two.
2. Look for rub marks on the backside of the crank pulley. Yes?
3. Use large pry bar to move the crank fore and aft. Movement?
4. Remove engine and pull off oil pan.
Why does a thrust bearing fail?
Too stiff of a pressure plate? Mine is a SPEC stage III
Improper clearance when engine was assembled? .015"?
Poor quality parts?
I am open to suggestions or your experience with this type of failure
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Spec stage III PP is a stock unit with blue paint.
Usually, this is caused by starting the engine with the clutch depressed while using a harder than stock PP. I don't think this is the case for you, however.
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
Recent auto to 5-speed swap? One of the shop cars was fine till we put in a 5-speed. And with a stock pressure plate they went bad in a hurry. Not 100% sure on the swap being the cause but the timing was right for it.
