harness to knock sensor?
bombinuass
431
Dahlonega, GA
ok i bought my supra about 3 weeks ago and i finally found out that my knock sensor is unplugged. theres a lil green connector hanging near my starter. i cant seem to find the plug from the harness... can someone tell me where to locate that plug? ive searched for it and all ive found was how to rewire them. idk if mine needs rewiring yet. id like to see if the connector is still there and just wasnt hooked up. and also theres 2 on a 7mgte correct? wheres the other sensor on the motor?
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
If you mean two knock sensors then it's Just in font of the one by the starter about where cyl 2 is, very easy to find, especially if the alt is off
shaeff
Kurt is FTMFW x2!!!!
11
Around
No, this is not my car, it's a pic I stole from Google.
bombinuass
431
Dahlonega, GA
thanks shaeff. im trying to where i plug my sensor into tho. idk if the harness is gone or if i need to rewire it or what. ive found your rewire guide and ill use it if i need it im just trying to see if my car still has the original harness. i just cant seem to locate it. im not familiar with supras i just bought mine for 800$ running. but if it is cut or gone or whatever i will rewire it. someones had this car apart and didnt put it together right.
shaeff
11
Around
You said you see a green connector hanging, that's likely the KS connector. You could continuity check it before reconnecting it, or just slap it back on and hope for the best. I'd prefer to test the wires first, though.
ben1984j
159
Ft. Collins, CO
You have a pre-89 so you'll have to remove/pivot the starter to get to the rear KS....so might as well do that now, once you do I bet you'll see it.
