Well i fixed my very slightly blown head gasket just last weekend. Ever since, i have noticed that when the car is still hot and i go to turn it back on, after sitting maybe 10-15 minuets, it cranks for a very long time before it starts. Starting in the morning or any other time when the car has cooled it starts rather quickly. Previous to doing the head gasket, the car would start when hot, but would misfire/stumble a few seconds and then clear up, which was supposedly a common issue with pressure being bled off and getting vapor in the rail. When i had the car apart, the only things i did to the fuel system were spray the injector inlet screens out with brake clean, clean the whole exterior of the injectors, and replace the insulators on the front and the o rings on the back, I put some assembly lube on the o rings to make sure there didn't rip when pushing them into the fuel rail. I have no fuel leaks on the exterior anywhere. I just tried to jumper FP and B+ in the diagnostic box under the hood, but when i did so, the fuel pump relay on the opposite side of the engine compartment buzzed like crazy. I did however hear fuel moving, but barely over the buzzing fuel pump relay. This relay does not buzz like this with the car running.
What should i check next? Should i hook up a fuel pressure gauge and check that the pressure holds for 5 minuets like the TSRM states? Thanks for any insight!
