HAC sensor and A/C temp switches
scotty
476
Norway
scottnicholas.net
Hey!
Doing my GE GTE swap.. and I've now got HAC sensor and A/C temp switches connections on the harness. But as far as I know I don't have the HAC sensor unit, and got no where to connect the A/C temp switches.
Do these two have to be connected in? Would I have to buy a HAC sensor unit?
Thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
This is not a simple question... the HAC sensor was exterior to the ECU only for the early model GTEs, then in '89 it was moved into the ECU itself. If you are putting in an early model GTE harness / ECU, then yes, you'll need one of these sensors.
Hopefully someone else will chime in about the AC.
