Whats the approx h.p. loss thru the drive train or whats my aprox h.p. with these mods?
Here's my mods, 3' exhaust, 18 p.s.i., 57 trim, engine management, will use the Lexus if I need 550 injectors.
I'm trying to calculate what size injectors to use, R.c. has work sheet to use to select the correct injectors size. But they want to know what the horse power is at the crank. Every says, take it to a Dyno, How can I take it to a dyno, if I don't have injectors to even start the car, let alone go to Dyno. What? put my stock injectors in and see how it gose? I know every probably is gonna say 550 is the way to go. I've also heard 440 has also supported 425 h.p..Everybody's car is different, that why I can't get a consistant answer, yes this a dead horse. The work sheet should be posted as a sticky.
