This is by no means comprehensive in that there are various options for each car but should give an overview of the various different models of mk3 Supra.
The Supra started off life as the Celica-Supra but by the time we reach the mk3, Supra was independent of the roots with Celica. "Supra" is derived from
Latin that stands for "over, above, beyond, or greater than" (Wikipedia).
All of the supras are :
- Fuel injected
- DOHC
- 6 cylinder inline 24 valve engines
- Front engine/rear wheel drive set ups
- Dual wishbones front+rear
1GGE
Displacement:2.0
Aspiration:NA
Power:150bhp @ 6200RPM (Pre August 88 138bhp @6400RPM)
Torque:135 ft/lbs @ 5600RPM (Pre August 88 119 ft/lbs @4600RPM)
Gearbox:5 spd manual or 4 spd auto
Aero:Available
Additional:This is the baby of the bunch, some people love them but most find them underpowered
Chassis:GA70
Bore/stroke:75/75
Compression:9.5:1
1GGTE
Displacement:2.0
Aspiration:Twin turbo (parallel)
Power:210bhp @ 6200RPM (Pre August 88 182bhp) @6200RPM)
Torque:203 ft/lbs @ 3800RPM (Pre August 88 177ft/lbs @3200RPM)
Aero:Available
Additional:Better than the 1GGE but still lacking in performance compared to the other variants
Chassis:GA70
Bore/stroke:75/75
Compression:8.5:1
1JZGTE
Displacement:2.5
Power:280bhp @ 6200RPM
Torque:269 ft/lbs @ 4800RPM
Gearbox:5 spd manual or 4 spd auto (R154 or A342E respectively)
Aero:Available
Additional:Very capable engine, solid, reliable and capable of big power. Similar to mk4 Supra engine. Thanks to Adi for this info-
1. The 'Limited' is the highest spec (and rarest in the UK, only 2 known), including the following standard equipment:
Digidash (digital dashboard rather than traditional dials)
Aerotop - removable panels in the roof
Torsen differential
Leather/Suede Combo seats
Electronically retracting wingmirrors
Highly adjustable electric drivers seat (more than normal)
TEMS (Toyota Electronically Modulated Suspension)
Various items such as anti hijack automatic door locking, seatbelt pretensioners etc
2. The Type 'R' which is a stripped out version produced in limited numbers (although readily available in the UK due to importers
favouring these)
Reduced weight
No toys like the limited
No ABS
Recaro interior
Momo steering wheel
Standard dash
Torsen diff
Bilsten shocks
3. The GT, base model 1JZ
Similar to the UK car, but can have some (but not all) of the options that the limited has
No torsen differential
No suede/leather option
Further to the above options, you can identify your car by a badge on the back (if still present) or the VIN will tell you
Chassis:JZA70
Bore/stroke:86/71.5
Compression:8.5:1
- Fuel injected
- DOHC
1GGE
Displacement:2.0
Aspiration:NA
Aero:Available
Chassis:GA70
Bore/stroke:75/75
Compression:9.5:1
1GGTE
Displacement:2.0
Aero:Available
Chassis:GA70
Bore/stroke:75/75
Compression:8.5:1
1JZGTE
Displacement:2.5
Aero:Available
Torsen differential
favouring these)
Reduced weight
No ABS
Recaro interior
Momo steering wheel
Standard dash
Torsen diff
Bilsten shocks
Chassis:JZA70
Bore/stroke:86/71.5
Compression:8.5:1
