GT40-88 dyno charts wanted. :)
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Anthony's
and blk dev
any more? :)
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
http://www.supraforums.com/forum/showthread.php?t=234550&highlight=blackdevilsupra+dyno
That was with a leaking head gasket blowing out the spark, and tuning Tps, emanage, vpc issues. It will make more power if tuned right, and no mecahanical isues. IMHO it was very responsive for a 65mm Turbo, with great top end power. The above is black devilsupra's dyno. I made a few passes on the GT4088 with the bad HG but as you can see the ignition was being blown out by the leaking HG. I still have the turbo, but I got a great deal on a gt4067r! If my cams get in in time I will dyno this by months end with my new Wolf V500 thats waiting on the floor.
I will dig up some other passes I made when we were trying to figure out the ignition problem. My 474rwhp and 449torques was at 22psi. I feel with the head gasket issue under control it woud have made over 500 at the boost level!
suprarich
Guest
Nov 9, 2005
2,187
ohio
suprahooked said:
What a/r s was on them gt4088 in the dyno sheets? I just bought a percision gt4088 with 96 a/r.
With all the right stuff to support yours, you should see 600-650hp
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
suprarich said:
Month????????
PTE said that they have a huge backorder on them from Garrett, and it would take 6-8 weeks to get to me. It's been about 4 so far. It's all good, there's too much snow on the ground right now to be doing any car work anyways.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Im at 12psi tuned with perfect a/f ratios on the WB. SARD ecu, SAFC2.
Slips my stock A340e in 2nd and 3rd gear if i let it shift by itself when in boost (have to manual bump it off the throttle and its fine). Full boost in 1st gear at 4k (not bad for the WG slamming open).
Ill have charts soon to support this.
