Overview:
I relocated my battery to the trunk and would like to rerun all the grounds to avoid using the chassis as a conduit.
Please bear with me, I am not an electrician and find wiring diagram intimidating I have read through a bit of http://www.autoshop101.com/ on electrical but did not find much information on grounds.
Current Routing:
Currently there is one 4 gauge wire from battery to chassis in rear near battery, another 4g wire is ran from rear to a distribution block under passenger side glove box.
A 4g wire leaves this dist block to another located in center of engine bay above engine which Is currently grounded to the right side fender wall as well as to the block.
Proposed Routing:
Ideally I would like to run all ground points in cabin back to the first distributor and all grounds in engine bay back to the second. With the neg terminal on battery ran to the ground point in the rear hatch.
Questions:
What confuses me is noise from other electronics and ground loops. If any one could shed some light it would be appreciated.
-Ground loops are usually caused when the (-) negative ground returning from the amplifier to the battery has a high resistance; or the
wire or metal frame used to send the (-) negative ground is not the best path back to the battery forcing the (-) negative ground to fight
to return back to the battery. Source
What grounds can share the same distribution block or does it not matter?
What grounds should be closer to the battery/ father away or does this not matter either?
What other grounds are there besides those listed below? ex: The ignitor, coilpacks etc.
Where are all the grounds?
TSRM Ground Reference
A - Right Fender - It is right under your upper IC piping where it travels through the fender
B - Intake Manifold - Under intake manifold, I believe stock it is attacked to same bolt as the metal vacuum line there.
C - Left Fender - Directly under the fuse box. You can follow the bracket on the ignitor down to this point.
D - J/B No 1 Set Bolt // E - Left Kick Pnael // F - Radio Left // G - R/B No 4 Set Bolt // I - Floor Center
H - Floor Left // J - Floor Right // K - Back Panel Center
As I attempt to find all of these I will try to get pictures up of each location.
Current Routing:
Proposed Routing:
Questions:
