got a hold of a complete 2jzge front clip
jo7mge
ENIGMA
Jul 19, 2007
52
Anaheim
would the 2jzge be a complete plug and play into an 90 NA i have the mt ecu and complete wireing harness what else would i need to make it work thanks for input guys and i dont want to go turbo before anyone suggests it :icon_surp i wanna see what kinda power i can put down with an NA :naughty:
gixxer750
2jzget comingsoon!
Mississippi
nope it won't just plug and play. You will need to do a good bit of wiring into the car. Yes, the engine will bolt right in, but there will be some little things that need to be done.
jo7mge
ENIGMA
Jul 19, 2007
52
Anaheim
okay thanks how would i go about it being obdII i believe? i want it to be legal smoggable if you will so than i can work from there on building it is there a write up on the wireing diagram for the conversion ?
Satan
Tampa
What clip do you have? MKIV, Lexus? What car is it going into (MKIII)?
You'll have most of the same things to address, like you would with a TT swap... Motor mount brackets, tranny/driveshaft, oilpan, exhaust, wiring, etc.
I am getting ready to put a TT in the wife's MKIV and move the NA to the 1990 I still have. Will not be getting to it for a bit though, so you may be done, by the time I can give you some input on that one.
Satan
Tampa
I believe that the engine's got a rear sump oil pan... so, short list...
1. Figure out PS line
2. Tranny tailshafts and shifter bracket/mount are different - Custom DS, does shifter fit?
3. Get motor mount brackets from a JZA70
4. A/C - 7M Cap?
5. Wire harness is already long enough - Figure out what signals/connections to dash/body harness.
6. Exhaust - I'd get Ebay headers
I think that should at least give you a few things to sort out/plan through. If you're really worried about the wiring, I'd get Dr. Tweak to handle. I "think" I know what I'm doing and still going thru wiring drama w/the TT swap.
ihiryu
209
TX
currently i'm running 7mgte electronics on a 2jzgeT. Check dok33 page's build thread. You might be able to use all your 7GE electronics, so long as your dizzy can fit where the 2jzge dizzy goes.
I would think anyway
