going T
wchico15
BoOoSt
Jul 18, 2007
114
Florida
im going na-t using a turbo block and electronics. when im buying parts like for example the starter, do i go for a turbo starter or stick to non-turbo cuz of the tranny? is there any other things i should swap like the upper y-pipe intake manifold and throttle body? or just keep them? any other swaps i should know about?
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
after its all said and done you could just but a turbo motor for the same price as getting everything separate. but it not you'll probally also want the turbo afm and injectors.
wchico15
BoOoSt
Jul 18, 2007
114
Florida
i've calculated and it would be about the same as getting a jdm motor but the difference is i'll have a rebuilt motor becuase im replacing bearings, pistons,piston rings,block cleaned and checked,metal headgasket,etc. so its much more worth then getting a stock jdm motor for $1500. i've already begun collecting parts like the injectors and the coil pack. just need to know everylittle swap that must be made other than electronics.
DegreE
500
Memphis & Miami
wchico15;1007054 said:
should i switch out throttle bodies and the y-pipe for the 3000 pipe?
You'll have to.
I think the TPS on a GTE is Different from a GE.
It will also make it easier to mount you coilpacks.
DegreE
500
Memphis & Miami
wchico15;1008119 said:
I've calculated and it would be about the same as getting a JDM motor but the difference is I'll have a rebuilt motor because I'm replacing bearings, pistons, piston rings, block cleaned and checked, metal headgasket,etc. so its much more worth then getting a stock JDM motor for $1500. I've already begun collecting parts like the injectors and the coil pack. just need to know every little swap that must be made other than electronics.
Intake Manifold
Throttle Body
3000 Pipe
Valve Covers
Coilpacks
Power Steering Resivior
