I've been looking through the forums here for several months now and recently my friend bought an 88 Turbo!
It's neato!
I like it!
Seriously, I want one, but it's an automatic so I need to start searching on how to tune up the A340E.
As far as the boost guage is concerned though it only gets up to 2 psi. LOL :sarcasm: ............ :1zhelp:
However, my 5m still accelerates faster than it, for now!
Quick question,
If a code 51 is present does that mean we wont be able to do the timing correctly the same way on the MKII Supra you cannot set the timing if the TPS is not adjusted?
Based on this:
http://www.supramania.com/forums/showthread.php?t=38775
The CPS does not get set to 0* right? The timing should be set to the right of the spot indicated in that link? 10* BTDC, right?
As of now, the timing is jumping all over the place, I don't think computer control is disabled when shorting the diagnostic ports to check engine codes.
Does the automatic have to be set in 'N' to adjust timing?
Thanks in advance, sorry for noob questions!
It's neato!
I like it!
Quick question,
Based on this:
