Getting code 11 and abs light
SupraKid
138
Santa Teresa, NM
Put a tranny in my car, after putting it in and cutting the speed sensor wires because the tranny had diffrent connections. Go to start car and imediate check engine light and abs light. Go to drive car and doesnt shift up. Check codes i get 11 momentary interuption in power to the ecu computer. Can this be due to those connections i rewired? Any suggestions? Any help will be greatly appreciated!
SupraKid
138
Santa Teresa, NM
No i did not take it out, i saw that both trannys had 3 wires, so i just connected the ones from the previous tranny on to the coressponding wires on the other tranny. I just disconnected the ect to try the mechanical shift test and it shifted fine. At this point im thinking it might be that speed sensor. Atleast i know the trannys good.
