gearbox's
sketchy_89
20
adelaide
ok ive got a 7mgte right....bought a manual conversion (complete kit) for a grand...its a w58 gearbox (before u say anything its all i can afford) question is...will it fit coz it was off a 7mge cressida..would there be anything different from the 7mgte and 7mge that i need to change or wont it work at all?
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Nobody should give you shit for getting a w58 with a stock turbo set-up. It takes more than a stock GTE to come close to blowing up a w58 and they drive at least as well if not substantially better than the truck/tank transmission R154.
That being said, you can use the w58 from a cressy, but the clutch set-ups are different, you'll need a new driveshaft if you had one for an auto, i'm not sure if clutch lines will be routed the same as well as other smaller items...
gaboonviper85
3,236
Northeast Philly
it will fit...you need an n/a flywheel, n/a slave cylinder, turbo or n/a master, braided stainless clutch line from driftmotion.com (unless you plan on getting the stock hardline), manual trans clutch pedal assembly from a supra, n/a clutch, now im not too sure if the w58 trans tail housing from a cressida is the same or not but im pretty sure it is so you may need a transmount...
too be perfectly honest...you are downgrading if you go with a w58 if youre sporting a a340 from a turbo.....keep what you have and fuck the w58.
sketchy_89
20
adelaide
yer but its the fact that i miss havin a manual car and i like havin a manual to drive...as i said this kit comes with everything...so wil lthe cressy pedal box fit or will i have to get the supra one?
sketchy_89
20
adelaide
does a w58 bolt straight up to a 7mgte or do i have to change the bell housing? and yeh will i need the supra pedal box or can i use the cressy one
