whatsup guys im in the middle of swapping in my used 7MGTE and im going to be using the GE tranny, so i got a aftermarket spec clutch and GTE flywheel all ready to go.. and now im stuck. i cannot get the old release bearing off the hub so i can install the new bigger bearing for the clutch. i've gone to levines' and napa and they say its a 50/50 chance the bearing could be switched but theyre unsure it will hold up because theres a slight size difference. so my question is for you guys who have done the SAME swap or just have infinite knowledge.. how can i get past this and install the new release bearing?????? thanks
