gasket material
gmann
19
calfornia
supra90turbo;1476525 said:
Safe, yes. Smart, no. Effective, no.
A FelPro Intake Gasket Set is very cheap.
how do i go about getting my hands on one of these FelPro Gasket Sets. the sooner the better.
Heavy D
358
worcester, ma
autozone sells felpro gasket, unless you guys dont have that which you should, also couple auto part stores like advance auto part, also you can go on autozone.com to check
mkIIIman089
Ohio
WOW! What were you doing with the intake manifold off if you clearly had no idea what you were doing? If I may ask... just so I know when your motor 'splodes in a couple weeks.
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
Felpro is alright as long as it has the silicone o ring for the coolant line. OEM is the way too go like Ian stated. I'd use copper spray as an added security.
PS: Stone is good also AJUSA.
oem is just the reg gasket with no o ring for coolant. oem fel pro they allwork but silicone will prolly blow out.
OEM does have a sealing ring around the coolant passage through the lower intake manifold flange...
well fuck me(please excuse my xmas eve drunkness) even the fel pro has the sealing ring.
Yep, and while it's needed, it still sucks as you have to get the old stuff off or you risk warping, or more than likely cracking the lower manifold.
