Gain Adjustment Worksheets for Piggyback Scalar
isnms
United States of America
Oklahoma
i80.photobucket.com
◊ Gain Adjustment Worksheets - SAFR, SAFC I, II & NEO, MAFT Pro & GenII ◊
Excel worksheets for popular piggyback fuel controllers.
Import your wideband data and calculate you gain adjustments.
*Not responsible for any way you use these worksheets. Verify your own math.
Current version - 6.9.27
Worksheets are attached at the bottom of the post.​
> SAFR Gain Adjustment worksheet .zip 167KB
11 set points, 50 rpm increments
http://www.supramania.com/forums/attachment.php?attachmentid=46957&d=1290358822
Use the following worksheets for tuning the device Hi load settings:
> NEO Gain Adjustment worksheet .zip 169KB
16 set points, 50 rpm increments
http://www.supramania.com/forums/attachment.php?attachmentid=46958&d=1290358893
> NEO Easy Gain Adjustment worksheet .zip 167KB
8 set points, 50 rpm increments
http://www.supramania.com/forums/attachment.php?attachmentid=46959&d=1290358931
> SAFC II Gain Adjustment worksheet .zip 167KB
12 set points, 200 rpm increments
http://www.supramania.com/forums/attachment.php?attachmentid=46960&d=1290358964
> SAFC I Gain Adjustment worksheet .zip 167KB
8 set points, 500 rpm increments
http://www.supramania.com/forums/attachment.php?attachmentid=46961&d=1290358991
  • SAFR_GainAdjustme&#.zip
  • NEO_GainAdjustmen&.zip
  • NEOeasy_GainAdjus&#.zip
  • SAFCII_GainAdjust&#10.zip
  • SAFCI_GainAdjustm&#1.zip
isnms
Oklahoma
i80.photobucket.com
Ok, it's posted. Give it a try.
At this version, you will have to round to the nearest 1/2% yourself.
There are so many settings on the Pro. This worksheet would only be useful to figure you scaling percentage and probably for just the Hi Load settings.
Let me know if it works.
edit: Well, SnapDrive is having a problem. The file is 0bytes every time I try to upload it.
On a good note, I fixed it where it rounds to nearest 1/2%
edit2: finally got it to upload completely
