fuse panel buzzing
full_thr0ttle
84
Toronto
i realize im posting after myself numerous times lol but i figured the updates might help anyone who reads it to chime who might have had the same problem
i checked for codes and im getting 14, 21, and 51..
21 is for the 02 sensor- makes sense because i dont have it hooked up yet, so im not raelly woreied about it
51 is for the a/c or the tps- im leaning towards the a/c since, again, it has yet to be hooked up
which brings me to code 14- something in the ignition, picked up a known good coil pack and ignitor today from a buddy, gona try them out and see what happens
Code 51 will always show if the AC button is on, regardless if the rest of the system is hooked up or not. ;)
full_thr0ttle
84
Toronto
i found the problem! it was a wire that was broken between the ignitor and the coil pack.. so the good news is that i finally figured THAT out and got the car to start...
HOWEVER, i went to start it up again, and now it seems that the fuel pump is not working, any ideas? its a brand new walbro pump.. i jumped the Fp to B+ in the diagnostic box, and nothing..
full_thr0ttle
84
Toronto
yea the ignition key was in the on position, the car cranks but i can tell im not getting fuel, just not sure why now, all fuses are good, as i said its a brand new walbro pump, cant see why it would just stop working
full_thr0ttle
84
Toronto
found the problem! turns out the wiring where the connector hooks up to the pump was shotty, played around with it and got it to fire up! thanks for all the feedback everyone, really appreciate everyones help throughout this painful process lol
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Did you ever figure out the buzzing?
I hooked up my dash today and heard the same thing, and mine is also the turn signal flasher
I'm guessing there's a short somewhere :(
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
So, it occurred to me, that these flashers increase speed when one of the bulbs is out, correct?
So considering i have none of my turn signals hooked up currently, I'm assuming this is the cause :biglaugh:
