fuse panel buzzing
full_thr0ttle
84
Toronto
hey guys,
i just went to start up my car today for the first time after the rebuild, and as soon as i connect the battery, there is a buzzing/hissing coming from the kick panel where the fuses are.. i can feel which one is buzzing, but i cant seem to find a diagram or picture that tells me what it is exactly
the car will not start either, not sure if it is because of that or not.. it is a black square that sits right above all the fuses
any help would be appreciated
kirk
full_thr0ttle
84
Toronto
here is the part im talking about thats buzzing, its the black square above the fuses.. could this be a reason it doesnt start? it doesnt even crank
full_thr0ttle
84
Toronto
yea i guess that wouldnt be the reason why the car isnt starting, thanks for the help- at least i know what it is now... onto the next problem lol
thanks guys
full_thr0ttle
84
Toronto
its actually a brand new battery, i get power to everything in the car.. when i try to crank, it does not attempt to turn over, i tried to connect a piece of wire from the pwoer on the starter to the square connector on the starter to see if i could get anythign that way, and i hear the starter shoot out, but still does not turn over...
90T04
Tucson, AZ
www.azsupras.com
Hmmm, that should definitely make it crank. Can you turn the motor over by hand? If yes, then I would check all your battery connections. You could be getting a voltage drop when cranking due to a bad connection at a ground or positive cable. If no voltage drop, all cables are tight and clean, battery is fully charged, and jumping power directly to the solenoid terminal of the starter does not make it crank, then the starter must be bad.
full_thr0ttle
84
Toronto
so it turns out that it was in fact the starter.. i went to crank it over to get some oil pressure before starting it up and unfortunately my oil pressure gauge does not budge, not sure if it means i have no pressure, or if the sensor or gauge isnt working..
full_thr0ttle
84
Toronto
yea i actually did eventually get it to start, but it only stays on for a second or 2, and then it dies out, and i do have pressure once it starts.. so now im just trying to figure out why it wont stay on
full_thr0ttle
84
Toronto
found some fuel under the car so im thinking i have a leak somewhere and that could be my problem.. gona take a better look tomorrow if its nice
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
make sure all your grounds are hooked up. there is one on the drivers side attached to the block. i believe it goes to the battery.
-pete
full_thr0ttle
84
Toronto
yea my ground from the block to the battery is connected, also have the one from the wiring harness to the intake manifold, one from the head to the body, and one from the tranny to the body..
plaaya69
87T Supra
Nov 18, 2006
947
10
Lake County, IL
Is the connector for the oil pressure sender clean and making a good connection to the sender. Their should be a rubber cover to protect it but I would inspect that. Also on the oil pressure gauge, the gauge itself has a little tiny metal peice that connects to a peice of plactic(mine broke awhile back). I would inspect that if you take your gauge cluster out as well as the connections on the back of the cluster.
full_thr0ttle
84
Toronto
the oil pressure gauge is actually working now.. im able to get the car to start briefly for a few seconds, but then it dies out..
im not too sure but i think it may be a fuel issue, i notice that after its running for a few seconds the fuel pressure drops to '0' and the car turns off.. i also have no residual pressure showing on the gauge after the car is off with the ignition key still on.. any ideas?
