Fuse box (+B wire) bypass question?
spawntaker
1jz lover
Nov 15, 2008
150
Conroe,Tx
i bought a na shell and dropped a 7mgte in. and for some reason the supra wouldn't start. the engine wasn't getting power. so i figured it was a wiring issue. after 1 month of looking into the wires and swapping three different sets of harnesses (other then the engine harness itself) i decided to bypass the fuse box and connect the +B wire straight to the battery and what do you know the damn thing starts. my question is is there any way i could just run the +B wire straight to the battery on a fuse or relay or maybe should i run a second set of EFI fuse and relay for just the +B wire to the battery? what would be the easiest solution to get it running without problems later into the future? the reason i ask this is because i was going to run it on just a fuse but i didn't want to do anything that would screw up the supra but on the other hand i don't want to go through the wiring because i'm to damn lazy. lol. just let me know what you guys think.
Heavy D
358
worcester, ma
i had the same problem, what i did was i took a 7.5 fuse and wired it to the battery and then to the +B, but if you dont have a good working battery it will kill the battery, but that was just for temporary.
spawntaker
1jz lover
Nov 15, 2008
150
Conroe,Tx
well after all the battery dose kinda go to the +B. it goes from the battery to a 15a fuse to the main EFI relay to the +B but i think i might just run a new 15a fuse and relay just for the +B itself.
