i bought a na shell and dropped a 7mgte in. and for some reason the supra wouldn't start. the engine wasn't getting power. so i figured it was a wiring issue. after 1 month of looking into the wires and swapping three different sets of harnesses (other then the engine harness itself) i decided to bypass the fuse box and connect the +B wire straight to the battery and what do you know the damn thing starts. my question is is there any way i could just run the +B wire straight to the battery on a fuse or relay or maybe should i run a second set of EFI fuse and relay for just the +B wire to the battery? what would be the easiest solution to get it running without problems later into the future? the reason i ask this is because i was going to run it on just a fuse but i didn't want to do anything that would screw up the supra but on the other hand i don't want to go through the wiring because i'm to damn lazy. lol. just let me know what you guys think.
