Fuse blowing linked to engaging reverse gear. Input needed
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Ok heres the story.
Whenever i enter reverse(R154) my fuse blows that controls, The gauge cluster, my windows and the seat power options.(15 amp, top row, closest to the driver.)
I know the car was in an accident where debris was run over, I was thinking its a possible short in the reverse sensor thing. I'm not entirely sure tho.
Any input to point me in the right direction?
Thanks
-Kyle
BTW, 1989 Turbo
Buddafucco
Beef Supreme
Mar 3, 2007
214
Tampa Bay
Not positive right now but I'm pretty sure your back up lamps are on the same circuit. Possibly water in the tail lamps.
Big Wang Bandit
Feb 21, 2006
7,551
Well its definitely in the same circuit. I'm pretty doubtful there is water in there. But I will check anywho. The car has had this problem for a good part of a year, and hasn't been driven for a good 4 months.
tissimo
Stock is boring :(
Melbourne, FL
wire is shorting out to ground somewhere between the switch and the tail lights.. power comes from the gauge fuse, goes through the switch then back to the lights and grounds in the back
ghetto fix.. unclip the reverse light switch at the trans...
or go searching for a frayed wire
tissimo
Stock is boring :(
Melbourne, FL
the wires come from the harness on the Drivers side, clips on top of the trans and the switch is located on the passenger side of the trans
jetjock
creepy-ass cracka
9,439
The back up lights are supplied off the gage fuse as is control power for the seat and windows so yeah, a short in that line will take the things you mentioned out. Something is shorted after the reverse switch so the problem must either be under the car towards/at the rear of it. That fuse should be 7.5 amp btw.
