yes in the hatch there are cover plates u unscrew and pulg wires u disconnect.
lol shaeff I as well!!
Justin727 said:yes in the hatch there are cover plates u unscrew and pulg wires u disconnect.
Justin727 said:yep. that door. then ur fuel tank straps, fuel lines, and plastic piece in the fuel tank door for the filler. slowly let it down with a jack.
Justin727 said:no you need to jack the car up and put it on jack stands. after if you get ur jack and push up on the tank some that plastic piece should come loose.
